engine haness pinout???
Im looking for a engine harness pinout from the 42 pin connector on top of the drivers side valve cover. I think I have some wires shorted together because power feeds back through the harness from the gpr and wont allow me to shut off the truck. With it unhooked it starts and runs fine. last winter I installed a push button to control the relay as a temporary fix, it worked ok I just want to get to the bottom of it. Hopefully one of you guys can help me out. 2002 f350 7.3L
Thanks, Michael |
Check the following link
DTS Articles - Coffee Table Books I believe the 98- 99 book would be a start, then check the 99.5 update. The harness did not change that much. Hope this helps. Check out some other things on DTS some good information there. |
Does this help?
