01 7.3 psd running bad
hi
this is my first post here so i hope someone can help out i live in Australia and even though the vehichle we bought was australian imported the dealers over here are rubbish and i am getting no assistance at all we have a 2001 7.3l turbo deisel powerstroke, only had the vehicle 3 weeks and until now had no probs yesterday, out of the blue the car started to run rough (loss of power) and a engine warning light came on and stayed on, didnt have much choice but to drive it home, ran rough all the way home, then jumped on the forum to see what i could come up with, after reading some posts, thought it may be the fuel water drainer. got up this morning and drove for only about 5 mins to workand it ran perfectly fine, decided to drain the fuel anyways, this has not helped, after driving for about 10 mins this afternoon the engine light came on again, and then runs like rubbish (has no power) it is going to be hard to get codes read here as the techs dont have much to do with the f series so was hoping someone may be able to give me some ideas thanks in advance !! |
You definately need to get the codes pulled or see if its throwing one... any tuner/module will usually read codes.you might as well try the CPS first since its only $30... then if that does not solve the problem - go into the more in depth investigation to track down the problem. Good luck and welcome to the .ORG!!!
thanks for your help so far, could anyone lead me to a page that would have instructions on the under valve cover removal (seeing i dont even know what they look like) LOL
hi
ran a obd II scanner on it today and it keeps saying no codes so not to sure what to do next ?? |
thta doesnt make alot of since seeing how the check engine light came on , unless the scanner you used isnt able to pull cdes on this truck, some scanners wont
sounds to me like it was the same problem my truck was having. it turned out to be the passangerside undervalve cover. the scanner wasnt pulling any codes at first. it took a better one to pull the codes. the was a ford wedge i used to hold it in place.
hi
had a company come out with a portable scanner and he could not pull any codes either, ended up at a local ford service centre, same problem, not sure what he did in the end but did eventually pull a code, didnt say what that was but has isolated the problem to a electrical problem between the dash and front wheel arch on the passenger side (driver side in america) will keep you posted thanks |
