Steering gear box popping, cracking, sqeaking noise - Ford Powerstroke Diesel Forum
Old 08-13-2007, 04:04 PM
I am a new owner of a good old 99 f250 PSD. This truck has about 170k and a 4 inch lift and 35 inch tires. I just finished rebuilding the front ball joints, spidle bearing, and replacing 1 axle stub and both hub seals. I have now noticed noise coming from inside my steering gear box i.e; popping, cracking, and sqeaking. While I was investigating where the noise was coming from I noticed that the nut that holds the extended pitman arm was loose, I tightened it in hopes that was my problem but its not, I was wondering if anyone else has had this problem and if it is as simple as replacing the box or something else? Thanks for the help.......
Old 08-13-2007, 09:25 PM
hows the slack in the steering wheel? check for loose tie rod also and grease your fittings. Would be a shame to have to get a new gear box. I have heard of people going to an aftermarket gear box, but I am not sure the cost these days.
Old 08-14-2007, 05:38 PM
Yeah I went thru everything that would take grease. I wondered if there was a stronger after market steering gearbox on the market. Auto zone wants $150 bucks for a rebuilt one. I just want to go thru all of the possibilities first. I also thought about looking into hydraulic steering but I am not sure what all that would involve. The first thing I am going to do is take the pit man arm off to see if it is damaged. I am sure that it has something to do with turning these big tires all the time.
