Bad Chip??? - Ford Powerstroke Diesel Forum
Old 08-05-2007, 03:31 PM
Bad Chip???
My truck has been dieing last couple of days for no reason. Its just dies like turning the key off. I started back sfter a few cranks every time until today. So I took my chip out and it started fine. I drove it a while then put the chip back in, wouldnt start, took it back out its fine. Do chips go bad???
Old 08-05-2007, 03:39 PM
did u d/c the batts when u put it in and it might be a connection on the pcm or the CPS?
Old 08-05-2007, 05:05 PM
the chip worked fine for about month it. It only died at low rpm cruising, never died when I was getting on it. I'll try cleaning everything again and reinstalling. Just dont know why it would do that after a month. If computer had bad connection it would do it stock. I guess
Old 08-05-2007, 05:06 PM
my moms did that and it was the CPS
Old 08-05-2007, 05:10 PM
How much?? hard to install??
Old 08-05-2007, 05:17 PM
does it do it with out the chip installed at all? did u clean the connectors installed. im sure someone thats alot more help then me will be along if not PM. I am going to bed for the evenin
Old 08-05-2007, 05:21 PM
BIG TRUCK, SMALL DRIVER
What kind of chip is it?
Old 08-05-2007, 05:37 PM
Today it was quiting about every 5 to 6 miles I took the chip out, and its been fine for around 40 miles or so. Its a TS chip burned by Wildman I'm going to call him tomorrow and see what he says.
Old 08-05-2007, 05:40 PM
I'm sure he'll be able to set you straight.
