ABS LIGHT STAYS ON - Ford Powerstroke Diesel Forum
Old 08-01-2007, 10:23 AM
ABS LIGHT STAYS ON
2002 psd 4x4 abs light stays on. the speedo works just fine. I checked the sensor on the rear diff and it looks fine and tight ... wtf is wrong >?
Old 08-01-2007, 10:28 AM
ADMIN AND TECH
get the code pulled , speedo can work and still turn light on, or it could be a front wheel speed sensor
Old 08-01-2007, 10:29 AM
anywhere to get the code pulled free?
check each sensor on top of each front wheel to see if they are loose?
how much is the tool to pull the code.
Old 08-01-2007, 10:41 AM
autozone will pull them for free
Old 08-01-2007, 10:43 AM
AS FOR THE pullers i have seen em 200 + online
Old 08-01-2007, 04:57 PM
autozone wont pull code bc their machine cant get it ... they said and I made them try. As for the sensors I checked the rear and the front 2...
If i am not mistaken, the front 2 go into the caliper (i didnt take the wheel off to check them, I just looked at their connection). When i had work done on the bearing on the drivers front, it looked like the mechanic did not string the abs line back the same way as the truck comes with , so I wired it back to default with it clipped in on the rubber flap.
Anywhere I can get codes pulled free ffs ?
Old 08-01-2007, 05:46 PM
they can do my 99 they have em online maybe try napa or some other place where u located?
Old 08-01-2007, 06:02 PM
same problem
I had the same problem. The light would come on occasionally, sometimes for seconds, sometimes for more than an hour. When I took it to the dealer they said there was no code stored. I asked the obvious question -- if the light comes on, should it always throw a code? Answer: Yes. Go figure.
Old 08-02-2007, 02:28 PM
how do i check the front sensors because I am pretty sure its the drivers side front sensor.
am I able to take the sensor off without taking the wheel off even? or do i have to take the wheel off and then unbolt the sensor from the back without taking off the hub.
please shed some light on my problem.
Old 08-02-2007, 03:12 PM
bumpity bump not really sure buddy a tech wil lbe alogn soon
