Crappy running 99 powerstroke (video inside) - Ford Powerstroke Diesel Forum
Old 07-30-2007, 10:45 AM
Okay, I had it scanned with a snap-on scanner. Codes are as follows:
P1106 dual alternator lower fault
p1105 dual alternator upper fault
p1107 dual alternator lower circuit fault
p1211 ICP pressure above/below desired
p1316 IDM codes detected
P0603 ICM KAM error
The truck starts VERY hard and runs like crap and acts like its going to stall until I floor it for the first time, then it will run fine and start okay the rest of the day... I am getting to the end of my patience with this crap... The CPS has been replaced, BOTH UVC harness clips have been successfully installed, and I just replaced both batteries yesterday. Any info will be GREATLY appreciated.
Old 07-30-2007, 05:00 PM
Putfile is being stupid but i cant upload the videos... 17 views and no responses ouch.
Old 07-30-2007, 05:07 PM
Beer Drinker/Ballast Guy
Wish that I could help bud, but I know absolutely nothing about codes. However, judging by the first 3, I would say you have something up with your alternator. Maybe someone at Autozone could check it out for ya...lol...j/k. I really don't have any idea, but I'm sure someone here does. Good luck and keep us posted.
Old 07-30-2007, 05:08 PM
ADMIN AND TECH
p1316 , injector wiring harness loose under valve cover , need to run injectior buzz test if possible if not pull one at a time until find which one is loose , p1211 , could be sevarl things , make sure oil is full and in good shape, disregard alternator codes, fix short harness problem, clear codes and retest , your problem should be taken care of
Old 07-30-2007, 05:12 PM
See told ya someone with more knowledge would be along...
Old 07-30-2007, 05:15 PM
ADMIN AND TECH
just read this again , i see youve already repaired short harness , then i believe i would cleared all codes to start over if you havent already
Old 07-30-2007, 05:24 PM
The ICP and ICM codes are nothing?
Old 07-30-2007, 05:28 PM
ADMIN AND TECH
the icp code may be a problem , and i figured the idm codes were left from previous repair to short harness , you also said poroblem was only whenfirst started , you may have injector sticking , then once you rev it up it clears up, that may be something to look into , i would like a little more info
Old 07-30-2007, 05:31 PM
Not the IDM codes the ICM KAM error what the hell is that? lol What info would you like?
Old 07-30-2007, 05:34 PM
P0603 is not a big deal, you dont have any information posted about the truck but by that code im assuming your truck is tuned. This code shows up when the computer has been modified usually.
