Help...I think I have a short I can't locate.... - Ford Powerstroke Diesel Forum
Old 03-17-2011, 12:36 PM
Feedback Score: 5 reviews
Exclamation Help...I think I have a short I can't locate....
Ok... So I installed my gauges, and while doing so I found my not-working remote start assembly. (Behind the light switch, where I was tapping into the wires for the gauges.)
A couple days later, I am driving to work like normal, and the "open door" light/chime go off.... I had my radio on, and the roads are REALLY bad this time of year, so I didn't think much of it, just figured a door was jarred from the road... no biggie.
Well, it has since happened more and more frequently... and I was driving yesterday w/o the radio and noticed there is an electrical "short" sound at the same time... my first thought was it must be the connections I used for the gauges... I stopped, pulled out the light switch, and checked them... nothing. Drove for a while with the swich pulled out, and figured out the "short" sound is actually coming from behind the fuse pannel.... under the steering wheel.
Keep in mind, I have NO blown fuses, and the truck works fine, there is no operational problems that I can find... gauges work fine....the only symptoms is the truck thinks the door is open... (Open door light, chime, and dome lights flash on) and there is a buzzing "short" sound.
I would apreciate any help.... I really don't want to have a bad short...and would apreciate the truck not catching on fire, if you catch my drift.
Sorry for the novel...
Old 03-18-2011, 06:27 PM
P.S. Mods... Please don't delete this post....
Old 03-20-2011, 11:18 AM
I don't have any help for you. I just want to say be sure not to park in your garage until you get this figured out. A friend of mines turbo Cummins diesel just burnt his house to the ground from an electrical short inside the cab.
Old 03-20-2011, 12:34 PM
I'm not sure..but I think I may have figured it out...
I went a good distance yesterday, and didnt hear one short and not one "open door" chime/light.
I found a plastic cover on a wire junction (The one on the brake petal) had come off and wouldn't snap down. So I zip-tied it down....and havent heard an issue since. I have only driven it once since, about 80-90 miles.... so we'll see.... but hopefully it doesn't have any more problems.
Thanks for the heads up. (I'm moving it into the livingroom now)
Old 03-20-2011, 03:09 PM
maybe your door chime module is arching.
Old 03-20-2011, 03:10 PM
Where is it?
Old 03-21-2011, 04:10 PM
open the door with the key in or lights on and follow the sound. it should be under the dash about the middle.
Old 04-03-2011, 07:19 PM
Aaaand..... It's Back.
Started up yesterday, and did it again today, quite a few times. This is really bugginh me, and I really don't need a fire, wtf.
Old 04-05-2011, 07:14 AM
My 2000 e350 did the same. It ended up being the rear door light switch was worn out along with a slight indendation on the door frame. Replaced switched but it still did it, just not as often. I placed gaffers tape (better than duct tape) on the door itself and has worked for over 4 years.
