Passenger side cylinders not firing? - Page 2 - Ford Powerstroke Diesel Forum
post #11 of 13 Old 03-17-2011, 07:44 PM
Bad Night's Avatar
Quoted: 5 Post(s)
Originally Posted by Gascan View Post
I have heard of a bad injector causing the IDM to send a message to the PCM, reporting a short. Then the PCM will then tell the IDM to stop firing a whole bank. This makes sense in this scenerio, because it runs fine for a couple moments. You can test the resistance in the injectors on that bank. You need to measure between the signal pin and the common return pin on the valve cover harness. It should read ~2.9 ohms.
Yea , I have seen this as well .
07 F-250 Outlaw , Rough Country 6 inch lift , 37-13.5 R20 Nitto Mud Grapplers , MBRP 5" Exhaust , 08 Mirrors , S&B intake , 5% Tint sides and back , 35% windshield .
Bad Night is offline
post #12 of 13 Old 03-22-2011, 05:51 PM
Originally Posted by jlansaw View Post
I have a friend that has a 2001 F450 7.3. He claims the cylinders on the passenger side aren't firing. The truck will start fine and run but seconds after the engine is running the passenger side cylinders drop. He says there is fuel, power and oil pressure. He has replaced sensors, wiring harnesses, and I'm not sure what all but he still can't find the cause.
I'm not a 7.3 mechanic but I am curious about what is causing this. Anyone have any ideas?
You need to get hooked up to the data link. with A reader that can perfom A buzz test on the injectors do it when its cold and then when its at operating tempeture. this test will buzz all of them at the start and then it will do them in numerical order. listen to them they will be loud if you hear a muted one or more cylinders ,then do the cylinder balance test . If you have any opens in the wireing it will post the codes after any of those test.Note the muted ones are A sign of A stuck solinoide.You can also look at icp pressure should be 500psi when cranking and fuel pressure should be 30 psi min to start. to test the fuel pressure there is A plug at the rear of the left head and on the front on the right head.
Roma is offline
post #13 of 13 Old 03-24-2011, 08:34 AM
This past November I had my #8 injector fail while driving home to my parents place. It started as a check engine light coming on only under acceleration (though the truck was not misfiring at all) but then the following day killed the driver's side bank of the engine while driving. After towing the truck home (with another 7.3L lol) I saw that the truck would start and then after a second, half the engine would turn off and it would idle really bad until I shut it down.
I hit the forums and ended up pulling the valve covers to check the gasket harnesses, but they seemed to look ok and were plugged in. (I stuck quarters under the connectors for the hell of it).
After using a snap-on scanner the following day, the buzz test said #8 injector was bad (high to low side short). I though I read somewhere (also mentioned above) that the IDM could potentially kill a bank of injectors if it sensed a problem with one of them? Don't quote me...
Definitely get a buzz test done. Quick and easy (if you have a buddy with a scanner...)
I wanted to mention though that I was able to eventually fire up and drive on 7 injectors for a while with the truck no longer shutting the bank down. It was definitely missing on a cylinder. Not sure if this was because I cleared codes with my SCT livewire or because I messed with the valve cover gaskets...
Oh, and replacing #8 solved my problem completely. Good luck!
2001 F250 CC Lariat <-- Sold...
2012 F150 CC FX4 Ecoboost! <-- Current
mustang90 is offline
