2002 no power 1900rpm thru redline - Ford Powerstroke Diesel Forum
post #1 of 12 Old 03-12-2011, 07:22 PM Thread Starter
Leroy88's Avatar
Exclamation 2002 no power 1900rpm thru redline
So my 02 has been acting strange. As stated it has now power. Idles fine dri ves fine if your light on the throttle taking it no higher than 2k rpm. I changed the oil and filter, the fuel filter iat the front of the engine. When you floor it and it downshifts the tach will drive up but slowly. It used to run hard up to the red and have ample power to do so.
I changed the icp for a new one thinking that was it but no change. I had removed my 5.6k resistor because it idles lopey with it and the new icp, idled fine before. So it wasn't the icp. Before I changed the icp I noticed when wot it smokes a light brown, not black like it used to when I bought it. I was told there's a spring and check ball where the return line goes back into the pump on the rail and if the springs broken it'll cause low fuel psi. I always buy fuel from the same station and have gone through 3 tanks since it started.
So what should I check? I looked at the boots connecting the turbo piping and they're connected and don't seem to leak. I can hear the turbo spooling so I know its not a boost issue. Judging from the brown not black smoke id guess its not getting fuel. There is no check engine light on.
I really need to getg this thing fixed, I use my truck as my daily and as my tow truck for my repo job.
The truck is an 02 4door 2wd auto 7.3diesel, k&n filter, straight pipe muffler. It had a 5.6k resistor but I removed it due to odd idle with new icp.
Thanks guys.
I am a machinist for the New Orleans Sewerage and Water Board. Ive been an inside machinist for 5 years now, and a 1st class one for 2 of those years. We have the tools to check threads, like I said, Im lazy.
07' F250 CC SB 2wd 43k miles
--RIP--
02' CC SB 2wd 225k miles
94' 5.0 GT 135k miles
Leroy88 is offline
post #2 of 12 Old 03-12-2011, 07:46 PM
dump the k&n.
But anyway sounds like a fuel problem to me.
Dietoremain is offline
post #3 of 12 Old 03-13-2011, 09:08 AM Thread Starter
Leroy88's Avatar
Well ill keep the filter suggestion in mind. I agree its fuel, where should I start diagnosing? I've already done the obvious: icp and forward filter atop the engine.
--RIP--
Leroy88 is offline
post #4 of 12 Old 03-13-2011, 10:04 AM Thread Starter
Leroy88's Avatar
Ok if the pump on the frame is bad or not working, could it cause my issue? Would my truck even run with that pump not working?
--RIP--
Leroy88 is offline
post #5 of 12 Old 03-13-2011, 06:27 PM Thread Starter
Leroy88's Avatar
So I just pulled the filter and cap, the bow is clean no sediment at all. Any one please help. I need suggestions on where to look or what to check or take apart and clean. I don't have a lot of money to spend on parts.
--RIP--
Leroy88 is offline
post #6 of 12 Old 03-13-2011, 07:16 PM
Mod Newbie
dhanna6powerstroke's Avatar
Quoted: 20 Post(s)
Sounds like low fuel pressure to me. You need to check fuel pressure at the bowl. I think it needs to be around 55-60 psi at idle. It will drop at WOT but not exactly sure how much.
dhanna6powerstroke is offline
post #7 of 12 Old 03-13-2011, 08:15 PM Thread Starter
Leroy88's Avatar
Ok, I will check the pressure. Assuming it drops off, I can assume its a bad pump, specifically the one on the rail? The bowl fills up fine. I'm going to check the ebpv aswell. I've done some reading and it sounds like if its caked up with soot it can cause a similar issue.
--RIP--
Leroy88 is offline
post #8 of 12 Old 03-14-2011, 09:34 AM
Mod Newbie
Quoted: 20 Post(s)
Yeah, if it drops a lot the pump is probably the culprit and it is the pump on the rail. Only has one pump. It can fill the bowl fine and still have low pressure.
post #9 of 12 Old 03-14-2011, 11:17 AM Thread Starter
Leroy88's Avatar
What if it drops off slowly? What's acceptable? I've been told there's a spring in the fpr that if broken can cause low pressure. How would I check this and where is the fpr located?
--RIP--
Leroy88 is offline
post #10 of 12 Old 03-14-2011, 12:24 PM
Mod Newbie
Quoted: 20 Post(s)
If it's a pump then the pressure will drop quick under a load. I know guys do a BB mod on the 7.3's but I'm not sure about the spring. I'll see if I can find some info.
