one glowplug - Ford Powerstroke Diesel Forum
Old 03-07-2011, 02:31 PM
one glowplug
ohms bad. valvaline blue oil. b50. starts rough in say 5F. will start rough on all dino as well. romp romp smoke. plugged in starts up fine. no smoke after warm up. im gonna replace the plugs but wondering if i shouldnt be looking deeper, at the squirters. opinions?
Old 03-16-2011, 05:02 AM
update;
with all 8 gps going it starts fine above 40F. below that its still rough. errrrrrrr
Old 03-16-2011, 05:10 AM
Semper Fi, Devil Dogs!
Im having the same issue... Subscribed I want to know the outcome, good luck
Old 03-16-2011, 08:40 AM
check ur relay, then check the duty cycle of the IPR then after those two check the pressure of the HPOP during cranking. all the duty cycles/pressures can be found on here some place.
