Truck wont start sometimes...help - Ford Powerstroke Diesel Forum
Old 07-16-2007, 10:04 AM
in the past month this has happened to me 3 times. I try to start my truck it just wont start. It cranks well but just wont start. Batteries are new, alternator is new. The past 2 times I just waited about 5 to 10 minutes and it started right up. Hopefully it does the same thing right now. Any ideas?
Old 07-16-2007, 10:55 AM
Send a message via AIM to rednek01 Send a message via Yahoo to rednek01
have you changed your CPS? From what I have read this can cause all sorts of problems and its prone to go out in the 7.3's
Old 07-16-2007, 11:00 AM
ADMIN AND TECH
before you buy any parts , check oil levl and is it in good shape and the best thing to do is have codes pulled
Old 07-16-2007, 11:24 AM
Is this during warm or cold starts.
warm starts would be best to change the Cam position sensor ( CPS )
Cold starts maybe check to see if the High pressure oil pump if filled ( HPOP )
Like scuffy said check your oil level b4 anything else
Old 07-16-2007, 11:38 AM
all fluids are were recently changed and i just checked them and they are fine.
this is on warm starts.
I thought it might be the CPS but just wanted other opinion. Went to the dealer and got it for $22. Now I just need to change it and see if that corrects the problem. Thanx
Old 07-16-2007, 11:40 AM
If thats the case It's the CPS.
Change it out and rock and roll
Old 07-16-2007, 03:47 PM
is there a "HOW TO" to replace the cps?
Old 07-16-2007, 03:49 PM
Desert Shield/Storm Vet
Here ya go 7.3 Cam sensor replacement procedure
Old 07-16-2007, 05:20 PM
You just gotta love this this.
Everything you need to know and then some
Shawn
Old 07-16-2007, 05:35 PM
you guys are life savers, I replaced the cps and that fixed all my problems. Thanx for everything!!
