EBPV DELETE? - Ford Powerstroke Diesel Forum
Old 02-12-2011, 04:57 PM
EBPV DELETE?
Hey all, I just finished installing a MBRP 4" turbo back exhaust, sounds great! (except for the LOUDER EBPV HISSING) so here it is... Which way should i go about killing this damn thing?
1) unplug it?
2) gut the entire thing out?
3) just destroy the flapper?
any suggestions from anyone who's already done this would be greatly appreciated. I don't care how i kill it, i just want it to die! but without causing other problems (via codes, leaks, etc etc.)
Thanks,
Richard
Old 02-12-2011, 05:18 PM
Johnny Law Brown
I just unplugged mine no codes and that has been two years
Old 02-12-2011, 05:21 PM
riddin' high
Send a message via AIM to Dasaliac03 Send a message via Skype™ to Dasaliac03
what do you unplug? mine is also a pain, sounds like a spaceship when the truck is cold
Old 02-12-2011, 05:26 PM
Thanks i'll try to unplug it then, do you happen to have a picture of what i need to unplug? or can you describe it to me. appreciate it!
Richard
Old 02-12-2011, 05:35 PM
Unplug it, and when you get the time, delete it. I'm soooooo glad I did.
Old 02-13-2011, 11:42 AM
I just deleted mine. The plug for it is on the front of the turbo pedistal. I never had any problems with mine but the actuator was leaking oil so I just gutted it and welded the hole shut and tacked the butterfly valve open. Seems to be working out fine.
Old 02-13-2011, 12:30 PM
Do you tow anything in warm climates? Just do it right and get the high flow turbine outlet. It's about .5" larger and will drop egt's about 50 degrees, maybe a little more. No butterfly valve in the new one at all.
Old 02-13-2011, 03:33 PM
unplug it for now, but if you plan to do any turbo work(aka removing it) gut it while you're in there! best thing i did.
Old 02-14-2011, 11:56 AM
thanks for all the help everyone! I unplugged it and all is well for now, I'll gut it when i mess with it, but until then, all is well. Once again thanks to all who commented!
Old 02-26-2011, 05:33 AM
I live in Ohio, it is @20 degrees here now. How would deleting it effect cold weather warm-up? Can I get by w/o it in cold weather or will it cause me problems when idling first thing in the morning while warming up?
Thanks
