Help with engine codes! P0605-and more!
CE light has been on since I got the truck abt. 5 months ago. My generic reader gave me 1 code--p0676-#6 glow plug failure. I finially broke down and got an Autoengunity and an ebay laptop just for diagnostics. 7 codes!! Po238-map sensor,po470,po541,po605-internal control module rom error,p0676--#6 glo plug and #7 I can't read what I wrote! p0676-I understand--P0238-I guess I'll change the map sensor. The rest I think I can figure out. What is po605-internal control module rom error??
Thanks to anyone able to help.
if you have autoenguinuity you should be able to clear the codes. do this before you replace anything. sometimes youll get a 605 when somone jumpstarts you and hooks up cables wrong or the batteries go dead due to leaving the door ajar and the dome light runs the batteries dead or a bad fuse. cant remember which fuse at the moment but check them all with a test light dont just look at them
