Wich battery cable to buy??? - Ford Powerstroke Diesel Forum
Old 02-09-2011, 09:42 PM
So I can not figure out what part number I should be buying.
I have a 01 F350 single Alt. Need to replace the pos battery cable.
Do I need WC9329D or WC95669? So lost. Cant figure out what the difference is or if one is just the starter side.
Help please.
Old 02-10-2011, 11:59 AM
the positive battery cable goes from battery to battery down to the starter in one piece with a small wire coming off that connects to the passenger side fender, best bet is to call ford, mine was just under $120
Old 02-10-2011, 08:07 PM
matter is correct on the configuration of the cable. You can also get them at one of your competing parts stores. Price varies between 65 and 100 depending on where you look and how much you want to spend.
Old 02-10-2011, 08:51 PM
Dealer wants $140, online around 85 to 110. But all of them have a different part number.
Need to know the part number.
Old 02-11-2011, 06:22 AM
You can go to the parts store and they can reference the numbers for you and get you one comparable. Is the one online from ford or aftermarket?
Old 02-11-2011, 08:08 AM
Afew of them are ford parts. They say, Battery to battery or battery to junction.
Battery to juction is $85, battery to battery is $110.
Old 02-11-2011, 02:54 PM
i would say from what you have stated it would be the battery to battery. battery to battery also goes to the starter. Hope this helps
