fuel filter drain leaking
i have a 2001 powerstroke.My fuel filter drain is leaking does anyone have any suggestions.
I just fixed the same problem on mine. It was leaking right below the fuel filter and I had fuel sitting in the valley of the motor. Watch this video, it is pretty common on 7.3s.
does this make them crank longer to start
just cycle the ignition a few times... should top off the fuel bowl. might run a bit rough for a few seconds.
If you are looking to rebuild it I have the whole dieseloring.com kit for rebuilding your fuel bowl which should fix all your leaks. I bought it but ended up deleting my fuel bowl, will come with everything needed to fix your fuel bowl leaks as long as it isn't cracked also wil included the fuel pressure regulator housing with 3 different springs to adjust your fuel pressure to get a little more power if you want $60 shipped and it's all yours!
You can get a new valve from ford if it is leaking, they are easy to replace.
I have just the 3 Piece o ring kit also that is the flurosillicone that fixes just the drain o rings from leaking $6 shipped and it's yours just trying to help ya fix your problem cheaply
