Erratic idle after Hard accel - Ford Powerstroke Diesel Forum
Old 01-31-2011, 12:17 PM
After accelerating hard im getting a very erratic idle bounces between 7-1100 rpms for about 10 secs then idles normal. any ideas
Old 02-09-2011, 06:55 AM
bump anybody
Old 02-09-2011, 02:43 PM
Mine did it and it was the cam position sensor. I accelerated hard to 35 mph and when I let off to go 35 it shut off. It had rough idle and hiccuped sometimes which from what I've read are all classic CPS issues. Hope that helped. 25 dollar fix would be nice for you.
Old 02-12-2011, 02:52 PM
just changed it bout to mths ago, if that is wat it is this is getting ridiculous be 4th one n 2 yrs. but Im going to order 2 of the black ones from riffraff
Old 03-07-2011, 08:09 PM
Fixed it was bad ICP sensor, I have also had an irregular idle for the last 8-9 mths turned out to be the pre filter in the tank was clogged, and after fixing all those problems I decided to install the black CPS and it idles smoother than it has in 2yrs. GRAY CPS is junk JMO
