After reading the post for several days and going back to my truck and looking for the source of the leak I found it
I have a leak under the oil pump where it conects to the front cover, ... I actually use one of my wife's makeup mirrors and was able with the truck running actually see the drops comming from the top of the cilinder and driping into the very very front of the valey.
Now I need help with instruction and pictures if posible on how to remove the high preasure pump from the front cover and "asuming" that there is a gasket there.
Funny I looked and clean several times the higth presure oil feed hoses and they are dry! to unclude the nut (end plug) and the turbo pedestal
Please let me know where I can buy the gasket or o rings needed (actually I will probably change the o rings in the hoses as I read that its the most common place for leak.
Thanks in advance, P
