Cranking but not firing.. - Ford Powerstroke Diesel Forum
Old 01-26-2011, 07:09 AM
I am sitting in a walgreens parking lot just drove up here just fine, I buy stuff come out and it won't start. It is cranking but won't catch, tach is working all gauges working fuel pump is humming.... Any suggestions before I call AAA??
Old 01-26-2011, 07:48 AM
is the wait to start light coming on? If not its a fuse but you must unplug the fuel heater bowl then fix the fuse.
Old 01-26-2011, 09:06 AM
Yeah wait light comes on
Old 01-26-2011, 09:09 AM
Illiana Chapter Director
You need to get a hold of a scan tool and monitor the ICP and IPR readings.
Old 01-26-2011, 09:10 AM
you can try unplugging the icp sensor and see if it starts. If its that with it unplugged it will o to a defualt setting which should idle the truck
Old 01-26-2011, 09:23 AM
IPR needs to be at least 500 psi to start and the ICP needs to be at least .85 volts
Old 01-26-2011, 09:30 AM
ADMIN AND TECH
icp needs to be at least 500 and ipr should be no more than 45 percent to start , if ipr duty cycle goes to 85 percent then its closing off to far , and there is a problem, icp voltage may be around .85 to .90
Old 01-26-2011, 09:34 AM
Oops, I had those backwards.
Old 01-26-2011, 09:35 AM
ADMIN AND TECH
just messin with ya
Old 01-26-2011, 09:44 AM
just messin with ya
Gotta be wrong sometime
