Door handle not working - Ford Powerstroke Diesel Forum
post #1 of 2 Old 01-25-2011, 10:46 PM Thread Starter
Shooter04's Avatar
My passenger side door handle stopped working this weekend. I picked up a friend and when he got in the truck it worked fine, but later that night when i took him home he couldn't get in. The inside of the handle works fine, it's just the outside doesn't work.
This happened to my passenger rear door about a year ago, I sprayed some WD-40 in it and it worked perfectly after that. But that didn't work this time.
Wish i could give more info but my door handle knowledge is a bit lacking
Anyone of any ideas for a fix? Or what a common problem may be?
Thanks!
Hunter
2000 F250 XLT SB SC Auto
6" Lift, 37" BFG KM2's, 18" V-Tec Raptors, DIY Intake, Muffler Delete,
Cortex 1950 (
), Kenwood Stereo/Amp/Speakers, Extra Cup Holders!! (
115,000 miles and rolling strong
Shooter04 is offline
post #2 of 2 Old 01-31-2011, 04:58 AM
Power Stroker
stroking 7.3's Avatar
Quoted: 2 Post(s)
Send a message via Skype™ to stroking 7.3
This is more info than you are looking for but it has very good pictures of the door handle. Hope it helps.
Lock Actuator Fix WITH Pictures! - Ford Truck Enthusiasts Forums
Thanks,
Bobby
'99.5 F350 4WD Crew Cab Long Box,
Foil Delete. Custom Airaid intake. Riffraff Boost Fooler. Riffraff FRx. Riffraff HPOx. Strictly Diesel In Tank Kit. Lifter Pump. F650 Dash Kit. Issopro Fuel Pressure and Trans Temp Gauges PHP Phoenix Tuner, Xenon Air Dam. Swamps Stage 1 Injectors. Train Horn.
stroking 7.3 is offline
