99 7.3 HELP!!no start, no wts, no power to fuel pump - Ford Powerstroke Diesel Forum
Old 01-18-2011, 08:11 AM
Ive checked all fuses under hood and under dash, Ive allways been able to fix this problem be disconnecting fuel bowl heater but this isn't the case. Ive checked ignition-seems ok, checked the fuel shut off. What else???
O ya I also have no tach movement. Pump runs when I hook it up direct.
Im about out of Ideas. pcm???
Old 01-18-2011, 10:12 AM
hello is anybody there, please help
I disconnected the fuel pump and tested the wires, red has 6 volts which is probably standby voltage with the key on until pcm grounds pump????(i don't know)
Help me my brains is smoking
Old 01-18-2011, 10:44 AM
You have no WTS which is a good indication that the PCM isn't running. You have checked all the fuses (especially #30-22-19) and you're SURE they're all good?
It will Never start until you get the PCM up again. Is the truck "chipped"? Have you checked the PCM connection at the firewall? Is there power through-out the Fuse panel? (especially the PCM related fuses?)
Old 01-18-2011, 02:06 PM
I have power at all the fuses so says my test light, the truch is completely stock, all connections good, seems like injectors not opening and no power to the pump(6v). Bad pcm has to be the answer it would explain wts light, no tach movement, no power to pump(well 6v).seems like pcm should be grounding and sending currents that are missing??? Truck wont run if fuel pump is wired directly-Thats why I believe injectors are not functioning, so basically everything that the pcm would monitor and control doesn't work. I just want to be sure before spending anymore money
Old 01-18-2011, 03:06 PM
Well, it's a call I don't want to make But, I certainly follow your reasoning.....
With a pin-out of the PCMs connector, could you verify it was being powered and grounded?
To limit the damages, have you looked at eBay for a refurb?
Old 01-19-2011, 05:51 AM
well I have a buddy gonna bring in his snap-on scanner over this afternoon see if we can't get some surity
Old 01-19-2011, 07:15 AM
Unplug your fuel bowl heater and leave it unplugged. Replace fuse #30. Yes, I know it tested good. Replace it anyways. It'll take 20 seconds. I've had fuses test good before when they're actually bad. Big pain in the ***.
Old 01-19-2011, 09:08 AM
Ok I did it anyways no luck
Old 01-19-2011, 09:10 AM
I just took pcm off to make sure it didn't have a chip or anything and nope its factory. I wish I knew someone that had a pcm I could try before going and buying one
Old 01-19-2011, 09:12 AM
If it had a chip in it it would be coming out the back of it where the black plug is right??
