MY 03 7.3 HAS FLUID LEAKING UNDER THE TURBO AND ITS DRIPPING ON THE BLOCK AND PUDDLING UP THERE...IT HAS A SCENT KINDA LIKE DIESEL BUT ITS LIKE LIME GREEN COLOR...WHEN I START MY TRUCK UP I CAN EVEN SMELL THE SCENT....HMMM YES IM A NOOB BUT I REALLY WOULD APPRECIATE ANY HELP OFFERED! THANKS
dont know it could be antifreeze with the color but idk about the scent sorry bud i hope you figure it out
well treated fuel is light green...dry and clean the valley out.. start the truck and look around the fuel bowl for any leaks.. its probably going to be leaking around the yellow drain valve lever..
It's like bright lime green color...in just 2 hours its leaked all over the ground ...Idk what to do thank y'all for all the help..will it cause any tremendous damage to my Truck
no damage just fuel that you are throwing away if it is coming from the drain valve
find the closest dealer and get a new one for like 60$ if not you can get it loose and get some rubber(bicycle tube)or any other materiel in between the valve and the filter housing that will seal the leak until you get home and order o'rings also check all fuel lines for leaks (they have o'rings and go bad sometimes) just turn on the car and get on top of motor with a flashlight you'll find the leak |
i agree with above post. i would have to say, clean it up, sit under the hood with it running, probably running from fuel filter housing.
I had the same problem. Turned out to be the fuel pump had a tiny crack in it.
99 and up fuel pump was moved under the truck driver side
| Tags |
| diesel, dripping, leak, odor |
