Overdrive Light Flashes - Ford Powerstroke Diesel Forum
Old 01-07-2011, 07:37 PM
I have a '99 7.3 and when I first put the truck in drive or reverse the overdrive light will start flashing and the truck has no power and kind of chugs. Once the truck gets moving and I drive for a while the light stops flashing and it runs fine. I took it to a local dealership and they said it was my turbine shaft speed sensor. I have replaced the sensor but the ruck is doing the same thing. Any help is much appreciated.
Old 01-08-2011, 09:00 AM
A blinking OD light is a transmission code. Odd that the dealer didn't see a code, perhaps it is resting when when light goes off. Check your transmission fluid you may be needing a new transmission soon.
Old 01-08-2011, 11:06 AM
take it to a good trans shop before you do more damage
Old 01-08-2011, 11:25 AM
Send a message via AIM to Strokeorcroak Send a message via Yahoo to Strokeorcroak
good bye transmission
Old 01-08-2011, 02:21 PM
Powerstroke Techie
First off which sensor did you replace? There are 2 of them on top of the trans that are the same. The front one is the tss (turbine speed sensor) and the back one is the oss (output speed sensor). Otherwise I have seen one of those connectors cause an intermittent connection issue that did the same thing.
Old 01-09-2011, 09:41 AM
I replaced the back one. I didn't know there were two. The dealership told me where it was and I didn't bother looking for the other one. I will get another sensor and replace the tss and see what happens. I really hope its not the transmission going out.
Old 01-09-2011, 10:39 AM
Powerstroke Techie
If you have the one that you took out you can install that one in the front position.
Old 01-11-2011, 12:22 PM
every time mine has flashed like that i ended up having to replace the speed sensor on the rear diff.... but i didnt have any power loss just a flashing light
Old 01-11-2011, 12:46 PM
I have a transmission for you...fully functional $1350 shipped
Old 01-11-2011, 01:19 PM
thats a pretty good price dude... ive been looking around (just did mine) and 1500 is about the norm for cheap rebuild... and well those that are cheaper have issues for example i have just over 1000 in mine and dude is about to pull it for the 3rd time..
