weird thump/thud when braking or accelerating - Ford Powerstroke Diesel Forum
Old 12-30-2010, 08:55 PM
it just started doing this and i cant figure it out. when i come to a stop and the truck rocks back to settle and it thuds. if i take of suddenly it thuds. it feels like its in the rear end but i cant be certain. almost like axle wrap but the opposite. not sure how else to explain it.
Old 12-30-2010, 09:25 PM
check you axle "u" bolts, i see you have a lift.
Old 12-31-2010, 05:12 AM
Possible motor mount
Old 01-01-2011, 07:08 AM
Did you look at Clunk, Thud, Bump, Double Bump, Thud on take off, Spline Grease Job thread?
Old 01-01-2011, 09:32 PM
Kodeman
Not sure if you have a crew cab or not. But I had the same problem. It was the carrier bearing in the rear 2 piece driveshaft. Its in the middle of the two mounted to the frame. Kodi
Put the truck in netural , block the wheels and get under it and push on the drveshafts. If it has slop. it needs to be changed
Old 01-02-2011, 08:32 AM
yes this was my problem
some grease will fix it
Old 01-08-2011, 05:45 PM
yes and i think thats it.
