My ABS light came on - Ford Powerstroke Diesel Forum
post #1 of 2 Old 07-03-2007, 07:47 AM Thread Starter
cblackb's Avatar
Question My ABS light came on
Hey all, I was on my way in today and hit a bump (actually a hole) in the freeway and my ABS dash light came on and now it stays on. Any ideas? I haven't got a chance to pull codes yet. The Brakes seems to work fine. Thanks!!
2000 F-250 XLT PSD Auto Super Cab SB 4x4
Magnaflow 4" straight-piped into duals
Eclipse Sport Trucks Body and Interior Conversion
Tinted Glass
Zoodad Mod
Diablosport Chip (don't know HP)
Foil Delete Mod
DIY/6637 Intake Mod
Oilguard Bypass Oil Filtration System
CCV Mod
HPX Mod
Mag-Hytec Everything
BTS Valve Body
Cobra 29 LTD CB Radio
IAH Delete
cblackb is offline
post #2 of 2 Old 07-03-2007, 08:33 AM
Probably just your abs sensor got knock out of whack. When my abs light came on it turned out to be my right front hub assembly. Brakes still worked fine but there was just enough play in the hub to set off the abs sensor. The hub assemblies are not cheap
Early 99 F350 4X4 6SPD Crewcab Dually
6637 Air Filter, MKO 4" turbo back to 5" straight pipe Exhaust 6" tip, Isspro gauges Pyro, Boost, Watertemp, DP Tuner, Stock 40tow,60tow,80econo, 120race, KCM S.S. HPX line, ITP Overboost Annihilator.
IDPisan is offline
