engine just cut off - Ford Powerstroke Diesel Forum
post #1 of 13 Old 07-02-2007, 02:44 PM Thread Starter
southern7.3's Avatar
engine just cut off
well it rained all day here n sc n when i got off work i decided to go check out some watermelons n corn i got planted. when i got to the field there was a lil mud so i started playin round n it. hadnt got much mud on the tires lately well neway i was spinnin n all that good stuff n i stopped to see how down i could get it n then get out with 4x4. neway i got it stuck in 2wd and i was givin it gas and it was turnin some high rpms but it wasnt redlinin when i got out the gas the trucks rpms dropped and it cut off. wut happened?
southern7.3 is offline
post #2 of 13 Old 07-02-2007, 02:47 PM
back in the saddle
shu873's Avatar
Not for certain, but a majority of the time a 7.3L cuts out its the CPS or cam position sensor. Its a fairly cheap and easy replacement so I'd say that'd be a good place to start...
Kurt
'06 True Blue/Silver 250 crew cab
ARP's, EGR blocked
AFE stg.2, MBRP 4" pipe
Air Dog 150, ITP reg. return
Bulletproof oil bypass system
Banks technicooler
Ride rite air springs in the rear
EGT, boost, and fuel pressure gauges by DiProcol on the pillar
Plus a few other odds and ends...
shu873 is offline
post #3 of 13 Old 07-02-2007, 03:19 PM
fishingjred73's Avatar
02 F-350 srw cc
DIY tymar intake
08 bed mod
fishingjred73 is offline
post #4 of 13 Old 07-02-2007, 03:32 PM
It may be either your pcm conection at the firewall, see if you might of had some rain water or muddy water get in the connection. also the cps connection. If they are both dry and tight then I would look at the cps.
Early 99 F350 4X4 6SPD Crewcab Dually
6637 Air Filter, MKO 4" turbo back to 5" straight pipe Exhaust 6" tip, Isspro gauges Pyro, Boost, Watertemp, DP Tuner, Stock 40tow,60tow,80econo, 120race, KCM S.S. HPX line, ITP Overboost Annihilator.
IDPisan is offline
post #5 of 13 Old 07-02-2007, 09:24 PM
lilredpowerstroke's Avatar
Did you get off the fuel peddle pretty fast? I've had that happen to my truck once in a truck pull. I dont think it is the CPS, just not enough fuel to keep it running becuase the electonics are kinda slow and cant keep up. You might want to get a CPS and keep it in the glovebox just in case though.
T.J.
2003 F-350 dually 6.0
Centennial Edition
Straight exhaust 34x10.50 Swampers on Black Rock Stars
Been a member longer than most of the moderators
Thats why I said most Tiff
Think you can trust the government? Ask an American Indian!
My old truck in action
lilredpowerstroke is offline
post #6 of 13 Old 07-04-2007, 08:54 AM
99SMOKR's Avatar
hahaha, yea having an extra CPS isnt a bad idea. Everyone Ive talked to with a psd had to replace it
1999 Powerstroke Diesel
K&N Intake, 4" downpipe to 7" Stacks, Edge Juice chip(with Attitude display), Bully Dog shift kit, X-wheel
352 HP
678 TQ (w/stacked EVO)
BUILT not BOUGHT
99SMOKR is offline
post #7 of 13 Old 07-04-2007, 09:03 AM
duct tape & zip ties
bigcountrysg's Avatar
I have had this happen to me a few times as well. Most likely there is nothing wrong with your truck. If you just took your foot completely off the pedal. If that is the case then it is typical to happen. From my understanding your tc was most likely still locked and the sudden drop in rpms caused the engine to stall. I bet your truck fired right back up too didn't it.
Your Actions Today, Decide Your Future Tomorrow
2005 6.0 Crew Cab Long Box Lariat, current truck
2004 6.0 destroyed by contaminated fuel
2002 7.3L burnt
bigcountrysg is offline
post #8 of 13 Old 07-04-2007, 09:10 AM
WILLIAM LORCH's Avatar
Send a message via MSN to WILLIAM LORCH
1, At about what milage does the CPS shoot craps??? I have a spair ford and a 3"ext an 10mm socket of cores hte wrench in the center consloe... Also is there any gain from installing the International one???? Any experence with these ????
WILLIAM LORCH is offline
post #9 of 13 Old 07-04-2007, 09:22 AM
A cps may fail at any time. There is no given mileage or approximate time when it will fail. As for tge international one compared to the ford one. I think the only difference is color. Some say the international one is better then the ford one. Well I got 100,000+ miles out of my orginal one from the factory. So I put the same one back in from the dealership. Now I have the new one that costs like 30 bucks from the dealership in my glovebox.
2002 7.3L burnt
post #10 of 13 Old 07-04-2007, 09:31 AM
99SMOKR's Avatar
yea I put one from NAPA in mine and it works fine
352 HP
BUILT not BOUGHT
99SMOKR is offline
