PLease help. - Ford Powerstroke Diesel Forum
post #1 of 13 Old 07-01-2007, 08:35 PM Thread Starter
PLease help.
Kinda new with the diesel stuff. I have a 01 cc 4x4 , auto. Last week i insalled guages , And A pillar. So all is fine and dandy, Then i had a stupid attack and went and washed the engine off at the car wash.Since then it hasn't ran right. The engine will lope at idle, Hit the load lever and 20 seconds later it might rev up or not. Nothing consistant.I found the little Green hose off of the air intake. Plugged back in. No help. OH yeh it has an AFE blue intake also. Any ideas would be of great help. Thanks.
Ittlgetit is offline
post #2 of 13 Old 07-01-2007, 09:45 PM
I'm not sure what it could be - other than water in any of the connections under there! But a Free Bump for you before bed! lol Good luck!
Blue01F250 is offline
post #3 of 13 Old 07-02-2007, 05:36 AM
Big Tone's Avatar
Quoted: 2 Post(s)
BUMP
Big Tone is offline
post #4 of 13 Old 07-02-2007, 05:43 AM
I would check the fuses.. check all wire connections..
worse comes to worse I'd take it to the stealership and see what they find.. I think they will check out the truck for like $100 or something like that...
good luck bud!
DrPMR is offline
post #5 of 13 Old 07-02-2007, 07:34 AM Thread Starter
Bump
OK so whats a free bump? Checked all of the fuses under the dash, All fine. Do i need to check fuses under the hood? Could i have hooked something from the guage set up wrong? Thanks
post #6 of 13 Old 07-02-2007, 07:40 AM
a bump is just a term used to bump the thread to the top so more people will see it "as new"
yeah, the fuses under the hood was what I was refering to..
Human error is always possible, go back and tripple check the gauge set up..
also, I dont know if its possible, but did you cover the intake with a bag or anything.. and did you immediately start the engine after hosing off the engine?
as I said I dont know if its possible, but maybe you sucked up a lot of water from getting it in the intake...?
DrPMR is offline
post #7 of 13 Old 07-02-2007, 07:41 AM
Is it even worth it???
ABOBB's Avatar
Bump means that the post doesn't necesarily add anything.. but it moves the thread toward the top of the list of latest postings. Doing so (in moderation please) will help the thread get noticed.
BTW.. other than answering your question... this is a BUMP!!!
ABOBB
Aaron A. Bobb
2002 F-250 SD ExCab, Short Bed, PSD, Auto trans, 4X4
Custom tuned 6 position Chip
Whelen CSP690 Strobe Kit (Installed @ Feb Indy Strokers Rally... Thanks Adam), ZooDad Mod
COMING ATTRACTIONS:
Heated Side Mirrors, Owner Built Rear Airbag System
Owner Built Front Bumper, Owner Built Tymar Intake
Owner Built Custom Exhaust, Rear Roll Pan?
ABOBB is offline
post #8 of 13 Old 07-02-2007, 07:48 AM
cj41foley's Avatar
sorry bud, I've never had any problem washing my Stroker, (knock on wood)
Jason
2006 F250 2wd 6.0 psd, 8.96 1/8th mile with canned SCT tunes, now running Spartan Hybrid Race tune! AFE Stage 2 PRO DRY S, 4" turbo back str8 pipe in front of rear tire, auto, crew cab short bed, ZOO DAD mod, 5% tint over the factory tint.
Track Times!
Reaction---.674
60 ft-------1.892
594 ft------8.370
1/8th ET---8.965
1/8th MPH--75.63
cj41foley is offline
post #9 of 13 Old 07-02-2007, 07:51 AM
I would think your possibilities are:
A blown fuse under the hood - there are a LOT of them!
Water in thru the intake - although I wouldn't think so
and the most likely is water in one of the many electrical connections under the hood all around the engine harnesses - you might unplug them one by one (at least the ones you can find and get to) and maybe blow them out with air and at least make sure they are all dry.
of course do that after checking the guage install
post #10 of 13 Old 07-02-2007, 08:50 PM Thread Starter
OK i will try all of these ideas tomorrow and let everyone know. I did have a freind do a general scan on the thing, He said there were no engine codes, But when i would drive it once in a while the bad light would come on, And then go off, Intermintaly, Thanks for the Bumps , And ideas. ( Itwontgetitnow)
