camshaft position sensor , look up underneath the front end , front of motor on the passenger side just past midway on the main crank pulley, bolted to the front cover. !0 or 12 mm and turn it and it pulls right out. The high pressure line should just need an oring or is the line worn ? Is the truck not running or are they saying to replace the ICP just cause it has fluid in it ?
The HPOP line is pobably fine, mine did the same thing and caused a leak and all I had to do was tighten the line with a wrench. ICP is a 10 minute job MAX, I did mine in the International parking lot with a cresent wrench.
Truck is running... I just have a puddle of oil under the truck when its warming up in the morning... ICP they said the oil got in it so it needs to be replaced. I can see the oil leaking from the oil line.
SCAGLE Ill check what you said. I noticed this on my own I havent had the shop look at it at all.
I have 320xxx miles on the truck soo if things should be replaced vs just a seal soo it permanently corrects the issue and I dont run into it down the road I am perfectly fine doing it.
I just want to make sure im not getting screwed
its deffinatly a job you can handle if you have some simple hand tools and time, if you swing by a international dealer somtimes they will check your motor for you free of cost (depends on where you are etc. etc. etc.) but the point is IF you have the time,money and a dealer that will work with you, you mine as well go ahead and take care of the known trouble spots that show up on these motors as they get high miles
Its been getting worse just used to be like a 1 inch spot now its up to about 6 its not puddling up yet and im not losing enough for my oil to be low (I try to monitor it closely) but enough to bother me and make me want it fixed lol
I do have a full set of mechanics tools im just so used to working on my car the truck is like 3rd world country haha. I think I just may try to tackle some of this myself though
There you go , no way to learn like just gettin in there and doing it. I personally think diesels are easier to work on. Clean the motor and the underside as good as you can with degreaser and start chasing the leaks , most are pretty easy fixes. Lots of bright and helpful folks on here who can lead you in the right direction.
If it doesn't snow ill start tracking leaks on sunday gotta get some money together for parts and then will be making all the fixes
Related Threads
Ford Powerstroke Diesel Forum
5.4M posts
265.8K members
Since 2005
