Windows Stopped Working! HELP - Ford Powerstroke Diesel Forum
Old 12-15-2010, 10:15 AM
powerstrokin
Send a message via AIM to drz400smoto
So on my way to class this morning I hit to button to roll my window down and nothing. I reached to passenger and one of the back doors and tried those buttons and no result as well. The only thing I could think of that caused it was washing my truck yesterday. I hosed off the engine bay, nothing crazy.. just with garden hose. I checked the fuse under the dash for power windows and its fine. I also checked the connection of the plug on driverside door and it seems fine. Can I unplug it there and measure something to help diagnose it?
Any other ideas?
Thanks ahead of time for the help!!
Old 12-15-2010, 02:30 PM
powerstrokin
Any ideas other than checking fuses?
Old 12-15-2010, 05:14 PM
Send a message via AIM to tristanlee85 Send a message via MSN to tristanlee85 Send a message via Yahoo to tristanlee85
The switch could be bad. I had an intermittent problem where they would work and then randomly not work unless I flipped the switch one way while slamming the door. One way to check to see if it's the switch is take the panel off, unplug the harness from the window switch and plug it in to the lock switch (assuming your locks work). If the window works then it's a bad switch.
Old 12-15-2010, 11:22 PM
powerstrokin
Thanks for info, I ended up figuring out it was a different fuse. The one for map lights, hood light, and lights for power window switches.
