Coolant leaking out of valve cover - Ford Powerstroke Diesel Forum
Old 12-14-2010, 03:56 PM
Let's go B's!!!!
Feedback Score: 5 reviews
I have been chasing a coolant leak for a week or so. I found and fixed leaks in three different places so far (t-stat housing, heater core connections, and flushing tee I installed). It is still leaking and I traced it as high as I could. It looks like it is leaking out of the valve cover on the passengers side and leaking down onto the exhaust manifold. The heater hoses that run above this are bone dry. This is as high as I can find coolant leaking. What could be the cause of this? Is there freeze plugs under the VC? What can expect to find here? Thanks Guys
Old 12-14-2010, 04:06 PM
Pull your dipstick out and see if it milky from water. If you have water under the valve cover, it's getting into the engine oil. It's possible to also have a cracked water passage inside the head.
Old 12-14-2010, 04:41 PM
Let's go B's!!!!
Theres no coolant in the oil from what I can tell, but I can't find find the leak source from outside the VC to save my life
Old 12-14-2010, 05:05 PM
Do a pressure test of the cooling system, you may have a pinhole leak in a heater hose that doesn't show up until the pressure builds up.
Old 12-15-2010, 06:32 AM
I don't think there's any chance it could be coming from under the VC....
It's just gotta be traveling around the lip and overflowing there or you'd have water in the engine oil.
Sometimes the fan can blow the liquid from an unexpected place. Fill it up, and yes, as Stroken7.3 suggested, get a pressure tester on it with the engine off. Sprinkle some talc around and wait
Old 12-15-2010, 02:51 PM
Let's go B's!!!!
Well I think I found it. There was a leak coming from a loose hose clamp in the heater hose that had the Max AC installed in it. I couldn't find it cause it was under the IC pipe. It looks like it was traveling around the lip like you guys said and collecting where the pictures show.
I tightened it up and I'll know tomorrow if it's fixed. Thanks guys
