Problems after lifting..
Alright guys, got the truck lifted today...6.5" procomp..however it turned into an 8.5" kit. Truck already had shackles and leaf mounts on the front. So anyway my speedometer is not working now, the OD light on the end of the shifter is flashing, and the ABS light is on.
We had to take the front drive shaft out as it was not long enough. Everything worked before hand. Where is the ABS pickup/sensor??? We checked out the Speed sensor, and it seems ok..none of the wires are taught.. Any ideas....???? Please help.. Thanks, Ryan. |
check all of your wired connections, some may have been pulled or jarred loose during the install, did you do this yourself or a bizness do the lift for you?
Bizness..we did a look over before I left ,but couldnt find anything. I'll give it a better look in the morning.
Well replaced the speed sensor, and still not working..guess its time to probe some wires.
Found the problem, pinched wires.
Everything is working now. |
glad to hear ya got it working
