Truck Dead - Ford Powerstroke Diesel Forum
Old 12-12-2010, 08:04 AM
Truck Dead
well its 30 outside just slightly snowing i never thought i would have to plug in the truck. Went outside to fire it up barely turned over and now its dead has 2 brand new batteries about 4 months old new alternator about a month old ive replaced the wiring going down to the starter im out of options i was thinking of doing the Stancor Relay mod but im out of ideas?
Thanks
Old 12-12-2010, 11:03 AM
i was in Minnesota last week mine started at -3 without being plugged
i have new plugs and a stancor relay
next week i have to change the oil and ill switch to a thinner oil for the winter
it is easy to check the plugs and gpr you just need a multimeter
Old 12-12-2010, 12:06 PM
Well what happening is i hit the key and nothing happens its as if on a manual truck you dont press the clutch.. (mines automatic) i made sure to check its in park even tried it in neutral nothing starter is not turning over or anything
TwEaK
Old 12-12-2010, 12:09 PM
are your batteries dead or you need a starter
i had a bad alternator this fall that will drain my batteries over night
you need to check batteries and alternator first
clean really good all connections on batteries first
