problems!! - Ford Powerstroke Diesel Forum
Old 12-11-2010, 05:20 PM
problems!!
im in need of a new cps im thiknking possibly a whole new pedal assembly and pcm because i keep getting code p0221 and my service engine light will come on, the truck shows no rpm movement when crancking so ill start by getting a brand new cps form the dealer, also what this code mean?
P0713 Transmission Fluid Temp. Sensor CKT High Input?
if anyone has any info or help id greatly appericate it ive been trying to diagnose my pedal loss problem and ive had transmission overheating problems in the past, is there sensors i need to chage out or something?
Old 12-11-2010, 05:32 PM
If it aint a CAT itsa DOG
Here is the code for p0221. I would start with the cam sensor and then if that doesn't help try the throttle position sensor. Also if there is an international dealer by you, go to them and get a blue cps. They run about $25. I can find the part number later. Its better than the factory grey one from ford.
P0221 "thottle/pedal position switch circuit
Old 12-11-2010, 09:51 PM
10-4 sir ill be goin and gettin the cps asap and i have already replaced the pedal postion sensor under the dash on the pedal assembly got it from my local main auto parts delaer as well as the cam sensor, guess its time to try the newest version, any ideas on the tranny code?? really gotta get this fixed ill loose my throttle in the middle of intersections gets pretty scary! lol thanks for the help keep bumpin me up!! thanks
Old 12-12-2010, 08:40 AM
going to border international to get my cps sensor right now 25 bucks, ill see if that fixes anything, what would cause the pedal sensor code tho if i just replaced my pedal position sensor? thanks back to top
Old 12-12-2010, 02:57 PM
replaced the cam shaft postion sensor with the newest version, and it didnt help at all, the service engine light comes on and i loose all pedal response after i drpress the pedal down a few times the light goes away and the truck will run normal, and the pedal is also very incostient in its reading! i need help asap!
Old 12-12-2010, 02:59 PM
any idea if it could be the pcm or pedal assembly last tiem this happened someone mentioned it might be one of those? also where can a guy go about shopping for a pcm or pedal assembly? thanks
Old 12-12-2010, 03:47 PM
Powerstroke Techie
The lack of tach movement when cranking doesn't mean that your cps isn't reading. You need to check the wiring between the pcm and the pedal. Have you replaced the pedal yet? I've seen a whole bunch of those fail. As far as the tft code if you overheated the trans it could throw the lite, you need to monitor the tft and see what it's reading.
Old 12-12-2010, 05:11 PM
i have not replaced the pedal yet but im going to google it right now and see if i can find one, im waiting on my guages to arrive via santa so my trans will be monitored shortly, ill have to check wires but im not the greatest with elstronics what should i be looking for? thanks back to top.
Old 12-12-2010, 05:32 PM
well cant find a thing on a pedal assembly for sale if anyone has a spare or knows where i can get 1 id appericate it lemme kno!
Old 12-12-2010, 05:52 PM
Powerstroke Techie
You need to look for opens in the wires while wiggling the harness between the pedal and pcm.
