Wiring issue? - Ford Powerstroke Diesel Forum
Old 12-11-2010, 09:21 AM
Wiring issue?
Having a problem with my early 99, kind of hard to explain what is going on so I took pictures. I believe there was an aftermarket alarm system put on it and its causing me to not be able to start the truck.
Truck has two batteries, and this problem has something to do with this extra connector on the one battery.
This wire connects into
And runs into the firewall then I believe it ends up at this red light on the dash that looks aftermarket.
http://img.photobucket.com/albums/v1...n/IMG_0236.jpg
When this red light flashes and clickes (sometimes it will flash fast sometimes slow, sometimes it clicks also and different speeds) The truck won't turn over. I had the problem once before and I replaced the connector on the end of the wire and it fixed the problem. When you play with the battery terminals the light will change speeds and clicking etc, but I can't get the light to go out this time and be able to start the truck. The fuse that the wire has going to it is good. Im pretty lost as to what this setup is and or why I need it etc. Any help would be greatly appreciated.
Old 12-11-2010, 10:35 AM
Air Assault!!
Send a message via AIM to MPTonyT
If you look up under the dash you should find a plug with a gray clip style cover on it and will probably have a nut in the center securing it. Look for a thicker gauge red/Blue wire if you follow it from the base of the ignition cylinder (shown in pic below) you should find where it has been cut in half and a relay installed between it two cut wires.
Remove the relay and connect the two red/blue wires back together. Worst case scenario... this connection could have been made somewhere under the hood but not likely.
I found a pic on the web that shows exactly what iw as talking about. see the pic below (this is not my pic, my installs are WAY better than this...) See the red/blue wire and how it has been cut in half? remove the yellow connectors and connect the red/blue back together.
Oh yeah.... Welcome to the ORG.
Old 12-12-2010, 07:41 AM
Thanks for the reply, I had a few minutes to look at it and found what you were talking about, there is a white wire spliced into the red/blue one, hopefully I'll have time to mess with it in the next day or two. What is the purpose of this?
Old 12-13-2010, 05:15 AM
Air Assault!!
Some sort of security "Starter kill"
