new glow plugs, wont start - Ford Powerstroke Diesel Forum
Old 12-10-2010, 09:30 AM
Exclamation new glow plugs, wont start
so my truck wouldn't start if it dropped below 40ish, so i changed the glow plug relay and put in new glow plugs, no change, it blows white smoke while cranking, so its cranking good and pushing fuel through the system, what should i look for??
Old 12-10-2010, 02:38 PM
Is your gpr actually pulling in?
Check output of gpr with a meter ?
the conections under the valve cover
Old 12-10-2010, 05:27 PM
well glow plug relay was bad from the get go, did my own test, jumped the relay with key on, heard glow plugs kick on, and only power to the main power stud, i jumped it for 10 seconds and it fired right up, so glow plug relay is junk.
Old 12-10-2010, 05:40 PM
what kind did you buy??? buy a western snow plow relay part number; 56131k or get a stancor relay. buy that one off line. they both last a long time and then western snow plow relay is only 11 bucks
Old 12-10-2010, 05:41 PM
so it says in your sig that you have a new hpop icp and "opr" what is that? do you mean IPR? lol
Old 12-10-2010, 06:35 PM
Get the Stancor #586-902 relay from mousers.com - under $45 delivered.
All wiring will fit with no mods,you won't be disappointed!
