Truck won't start - No WTS light
Truck stalled pulling up to a light. Tried to start with no luck. Noticed that the wait to start light doesn't illuminate. If I leave the key on for a couple of minutes it will flash very faintly. Tested glow plug relay and it is working. CHecked fuse 19 and it's good. Disconnected fuel bowl heater and still no light. Any ideas? Has the following codes
• P1670 EF Feedback Signal Not Detected • P0381 Glow Plug Indicator Circuit Malfunction • P0230 Fuel Pump Relay Driver Fail • P0231 Fuel Pump Relay Driver Circuit Failure • P0232 Fuel Pump Relay Driver Failed Off • P1662 IDM EN Circuit Failure • P0603 Internal Control Module KAM Error • P1211 ICP Not Controllable - Pressure Abow/Below • P1139 Water in Fuel Indicator Circuit Malfunction • P0640 Manifold Intake Air Heater • P1105 Dual Alternator Upper Fault (Monitor) • P1106 Dual Afternator Lower Fault (Control |
Do you have a chip installed
I did have a superchip, but reprogrammed back to stock when this happened. I also checked fuse 19 and 22. Both good. New observation though. When I turn the ignition key the key left in ignition chime with door open is chiming. After everything cycles through the chime goes off and then the Wait to Start light flashes.
Already change fuse 24 under the hood. Also swapped relays 30 and 31. I cleared the codes and I only have two now. P1105 and P1106.
OK, two new batteries. Still no wts light. Any one?
Possible PCM problem.
Probably, I think thats the next step.
The PCM is bad.
