First Cold Start of year and now oil leak!? - Ford Powerstroke Diesel Forum
Old 11-27-2010, 02:33 PM
Ok so this is the first time its been cold by me and i wanted to see how the truck started when cold so i left it unplugged over night. I went to start it about 6am and it started right up but i noticed it started leaking quite a bit of oil
i havent had a chance to look at it in the light yet so i dont know where its coming from but any ideas on what i should check?
it never leaked a drop of oil before this
the trucks an 02 7.3
thanks,
Brandon
Old 12-07-2010, 02:10 PM
I have similar problem,oil caming out son where from the left side.
Old 12-12-2010, 06:19 PM
Every winter my truck starts dripping oil out of the oil cooler at the front where the pipe goes into the block. When the weather warms up it quits. Just haven't gotten around to fixing it.
Old 12-12-2010, 06:29 PM
Oil cooler, dip stick port, but more likely the HPOP orings or turbo pedestal orings or EBPV oring.
Old 12-12-2010, 08:03 PM
dmd dmd is offline
With it starting with the cold it is probably the EBPV o-ring.... Mine started also... Just
have to track it down.. Not bad now, but if it is the pedestal o-rings it can leak very bad
once it gets going.
Old 12-13-2010, 04:40 AM
There s where my is leaking from when is cold just when it start in the morning then stop and when is warmer like yesterday 50f it does not leak.
