no wait to start light - Ford Powerstroke Diesel Forum
post #1 of 3 Old 11-23-2010, 07:45 PM Thread Starter
hey guys problem with truck... turn key on and no wait to start light... no transfer pump either, no aih or glr.... i have checked the fuse inside.... i have checked all fuses and relays outside.... everything is good.... got a ecm that is good and tried it still same thing.... i have a bulley dog gt but not installed yet.... so it is stock..... i even unplugged fuel heater even though it wasnt blowing fuse..... i checked connections and all that.... anyone have any idea what it could be cause right now i wish it was just a blown fuse.... thanks
roo1113 is offline
post #2 of 3 Old 11-24-2010, 06:23 AM
Quoted: 176 Post(s)
Feedback Score: 3 reviews
Even though I'm sure you've given fuse #30 a good look, put a test light on both sides or. better yet, swap with another one.
The lack of a WTS light in a good indication that the PCM isn't communicating. If you've tried another one, then it does sound like a power problem. I'd look further into that...
Is there power in the OBD-II connector?
Fuse #19 is another one that needs a good look.
What year is your truck?
With all those other systems out how about the supply to the fuse box itself? There are fuseable links that could be bad.
Mine had this problem -> POTENTIAL ELECTRICAL CORROSION if your truck is like mine......
NoRalPh is offline
post #3 of 3 Old 11-24-2010, 08:16 PM Thread Starter
yeah it has power to the obdII connector u hook a scanner to it and it say cant communicate with ecm... like i said i have tested the fuses and i checked all relays... so any other ideas... thanks
roo1113 is offline
