Smoke ONLY during cold start??? - Ford Powerstroke Diesel Forum
Old 11-08-2010, 04:55 PM
I need help! I cannot figure this out and niether can a 7.3 mechanic?? No codes are being left. I only get smoke in the morning but i live in Los Angeles so it does not get that cold. Truck starts easily without hesitation but always blows white smoke when engine is cold untill the engine warms up. Mechanic did the buzz test and a full diagnosis and was not able to figure it out. He asked to replace several sensors and i have but nothing has changed! Could it be a oil problem? I checked for blow by with the cap loose and it did not move just a small amount of smoke came thru the loose cap.
Old 11-08-2010, 10:30 PM
even in the not so cold if you're in an area with moisture it can build up on the exhaust and burn off as white smoke... not uncommon.
Old 11-08-2010, 10:57 PM
Hi even a mechanic was not able to figure this out.....this goes beyond moisture in the exhaust system. It is excessive but thanks your input.
Old 11-09-2010, 06:38 PM
Johnny Law Brown
If your not getting excessive blowby and you don't have a blown head gasket or bad injector cups then it probably is moisture. My 02 smokes a lil when its warm always when its cool out and my 95 always smokes when it first starts up I think its just the nature of them
