Can you change head gaskets with engine in the truck? - Ford Powerstroke Diesel Forum
Old 11-06-2010, 08:46 AM
Has anyone done head gaskets on their 7.3? How did you do it - take the engine out or can you do it with the engine in the truck without pulling the cab?
Any thoughts?
How much does one head weigh?
Thanks -
Scott
Old 11-06-2010, 10:31 AM
Yes you can do it...it is possible, but it is much easier with the cab off.
Old 11-06-2010, 12:43 PM
O.I.F. Combat Vet 11B
think a head weights about 100lbs or so.
Old 11-07-2010, 09:43 AM
Dang, 100 lbs would be a wrestling match under there. Well thanks for the replies, guys. I just discovered my leak - it's my water pump. It's leaking behind the pulley so I guess it's worn out already?!?! I replaced it with a NEW Airtech water pump about 20,000 miles ago. Warranty is up as of 12 months. WTF>!? Anybody else have bad luck with those pumps? Guess I'll put in a NAPA reman.
Better than blown head gasket I guess!
Scott
