diesel in the oil - Ford Powerstroke Diesel Forum
Old 11-05-2010, 07:07 PM
diesel in the oil
I think that Im getting diesel in my oil does anyone know how to tell if it's happening and how this could be happening 2002 f-250 7.3 Thanks
Old 11-05-2010, 07:37 PM
Is it "making" oil? As in does it get higher and higher on the dipstick?
Old 11-05-2010, 07:42 PM
I think so, I fixed an o ring a month ago and just put two quarts in and didnt check it so b/c its a little overfilled
Old 11-05-2010, 07:46 PM
you could send an oil sample to blackstone labs to see, I would wait a little more just to see if it adds oil, you could have just overfilled it.
Old 11-05-2010, 07:48 PM
inj or inj seal
Old 11-05-2010, 07:56 PM
Originally Posted by BraveHeartCalif View Post
inj or inj seal
But how can the fuel get in the oil? The oil is at a WAY higher PSI than the fuel. It would be the other way around.
Old 11-05-2010, 09:29 PM
if you have diesel fuel in your oil you have cracked injector cups its the only way diesel fuel can get in your oil.
Old 11-07-2010, 08:06 PM
injector cups
I just recently attempted to flush and fill my rad and noticed a strong smell of diesel fuel in the antifreeze so I took the truck to a local diesel repair shop. they said I have one or more cracked injector cups. It turned out to be just one cracked cup. they charged me 12 hours labour plus parts and while they were in there I told them to put new glow plugs in also rather than put the old ones back in. the truck has 140000 KLMs. This type of repair is beyond my skill level so it cost me dearly but if you can do the work yourself then go for it.
Old 11-11-2010, 03:42 PM
Easiest way to check for oil dilution is to pull the dipstick and wipe it on a white napkin or something white. If you have diesel fuel in your oil, you will see it seperate. The oil will remain in the middle and the diesel fuel will separate and make a ring around the oil. Injectors are your problem. The fuel will leak into your crankcase causing high oil levels on your dipstick.
