E-brake - Ford Powerstroke Diesel Forum
Old 06-20-2007, 02:41 PM
E-brake
Adjusting the E Brake need help
Old 06-20-2007, 02:42 PM
Thats Mr. Oil Leak.....
What do you need help with?
Old 06-20-2007, 04:17 PM
adjusting the thing
Old 06-20-2007, 04:20 PM
You adjust it like old drum brakes. There is a rectangular hole in the bottom of the backing plates. use a flathead or brake spoon if you have one and turn the adjustor. Works best if you can get the tires off the ground so you can feel if it is too tight.
