diesel leak!!
2002 f250 7.3, my wife sent me this video this morning of her truck leaking diesel fuel. Any suggestions?
Check up around the fuel bowl. Mine was leaking right there from the fuel bowl drain valve.
my 2000 f350 7.3 is doing the same thing
Mine started doing the same thing last winter... ended up being the fuel bowl drain valve O-Ring... Changed it out and it hasn't leaked since...
If you're in a pinch you could always flip the old o-ring over... it'll reseal and hold ya over for a little while or long depending on how lucky you get... |
any diagrams out there showing how to replace the oring? Remove the fuel filter and is it under the fuel filter? i have never messed with this on this diesel before.
Here's some good info for ya....
Fuel Leak and here's a link to drain valve repair write-up... Separator Valve Rebuild Good Luck! |
The valve is actually on the back side of the fuel bowl, can be a PITA to get the screws out and back in... but the above links will help alot. That's what I used when I replaced my O-rings...
thanks, i will check this out tonight.
The drain valve is on the back of the fuel bowl with the yellow handle looking thing. The o rings were my problem but I took it off and couldnt find any to go back on so I just put it back together and hasnt leaked a drop since and thats been about a year.
I replaced the orings and still have a drip from the valve. I am afraid to get the T-20 screws to tight. I am questioning if they are too loose though.
