Horn goin crazy - Ford Powerstroke Diesel Forum
post #1 of 16 Old 06-20-2007, 08:55 AM Thread Starter
00powersmokin's Avatar
Horn goin crazy
this mornin i woke up to the sound of my truck honking like the alarm was going off. but the horn would honk for approximitly 30 sec then off for 5 then honk for 30 sec. finily found the fuse for the horn and it quit honking. no it wasent the alarm what could this be . thx in advance
00 F-350 PSD
Hypertech
4" stright pipe
DIY intake
07 Yamaha Rhino
27"ITP MUDLIGHT XTR's
2" homemade lift
00powersmokin is offline
post #2 of 16 Old 06-20-2007, 09:13 AM
jphelzer's Avatar
to the site.
if you have a tilt-wheel, try changing the position. Maybe a wire is cut or having some other problem in the steering column?
2001 F250 Ext Cab LB 4x4
7.3L PSD, 4R100
Stock except for DIY Tymar intake and 4" exhaust
226K miles and counting!
jphelzer is offline
post #3 of 16 Old 06-20-2007, 09:15 AM
Your truck is possessed by an evil spirit sent from the Chevy or Dodge dealer?
At least that is the most technical explanation that I can come up with!
1996 F-250--Stock (at least for know
)except for a 2 inch lift
MUDDVOL is offline
post #4 of 16 Old 06-20-2007, 09:22 AM
duct tape & zip ties
bigcountrysg's Avatar
Ok you must be the spiritual mechanic.
Your truck was telling you it wants to go for a drive wake up and drive me.
Now did it rain last night, was your truck heavily covered in dew. Was there any sign of moisture in the cab this morning when you went out to your truck.
Your Actions Today, Decide Your Future Tomorrow
2005 6.0 Crew Cab Long Box Lariat, current truck
2004 6.0 destroyed by contaminated fuel
2002 7.3L burnt
bigcountrysg is offline
post #5 of 16 Old 06-20-2007, 09:25 AM
Member/MARINE
rajharley's Avatar
Send a message via Yahoo to rajharley
it was an evil cat that went peepee on his hood. Sorry. Hope you figure it out. I like to keep up on posts like this in case I run into the same stuff. That way I'll known how to fix it if it happens.
02 F350 XLT DRW CC 6X6, ZOODAD MOD, DUAL PRESS RELIEF VALVE, 4" TURBO BACK EXHAUST NO KITTY NO MUFF, TS 6 POS CHIP, HIGH PRESS OIL LINE X-OVER, AIRAID THROTTLE BODY SPACER, DIY INTAKE NAPA 6637, PYRO, BOOST, TRANS GAUGES ON THE PILLAR, BANKS TRANS COMMANDER W/TRANS SHIFT KIT, BILLET TORQUE CONVERTER, WASTEGATE DELETE W/MAP FOOLER, SKYJACKER SHOCKS & DUAL STEERING STABILIZER, REDNECK CELL PHONE, RANCH HAND BUMPER, RECON BIG RIG, FENDER AND CAB LIGHTS, AND DIAMOND PLATE ACCESORIES.
rajharley is offline
post #6 of 16 Old 06-20-2007, 10:11 AM Thread Starter
Yes monday we had a flood the truck was fine heavy rain all day. when i got in and took off some water fell out of the dash. then last night it raind prety hard all night didn't notice anywater this mornin. im going to take it to the ford house in the mornin becases now some thing under the dash is clicking
00 F-350 PSD
Hypertech
4" stright pipe
DIY intake
07 Yamaha Rhino
2" homemade lift
post #7 of 16 Old 06-20-2007, 10:14 AM
The GEM Module, most likely got wet. That caused your horn to go crazy and most likely is making that clicking noise under your dash. From my understanding the gem module is expensive.
2002 7.3L burnt
post #8 of 16 Old 06-20-2007, 11:21 AM
Conservative and Proud
Banshee34's Avatar
Quoted: 8 Post(s)
Let's hope something doesn't short out too! Let us know what the dealer says.
2001 F350, Lariat SC LB 4X4 PSD
Quadzilla Commander
Zoodad with Stealth Screen
The Org. Staff reserves the right to move, modify, delete or merge posts at our discretion and without explanation.
Banshee34 is offline
post #9 of 16 Old 06-21-2007, 07:19 AM Thread Starter
I called the dealer this mornin and they said they could look at it tomorow. I went out to put the horn fuse to see if it worked and some thing by the e-brake clicked 3 times. yesterday the clicking was under the raido. so idont know i guess i might have to go buy a duramax...........lol j/k
00 F-350 PSD
Hypertech
4" stright pipe
DIY intake
07 Yamaha Rhino
2" homemade lift
post #10 of 16 Old 06-21-2007, 07:42 AM
dustindiesel's Avatar
i believe the GEM module is on the fire wall behind the radio which may echo and sound like it is comming from different areas..mine is bad too i believe but havnt got a chance to replace it yet..i think its like 200bucks with out warrenty
a bad GEM module may mess up ur cruise control too
2003 psd 6.0
red crewcab
16" suspension lift, 48" michelin xml's on 20x10 black rockstars, 6000k hid's, crossover steering, zoodad mod, ccv mod, modified up pipe to delete egr cooler,high idle mod, mbrp 3.5 downpipe, train horns(also on remote), diamond plate tool box, recon smoked cablights, Code670 alarm/remote start,100w reverse lights, oil-based underbody paint
**soon to purchase SCT rockwell 2.5 ton frt/rear
-8,520lbs with me in it
dustindiesel is offline
