Crank case ventilation - Ford Powerstroke Diesel Forum
Old 11-01-2010, 11:42 AM
I built my own CAI and while doing so, removed the stock crank case vent tube that attaches to the CAI tubbing. I did so after observing all the damn oil it dumps into the air intake tube, then being sucked into the turbo. I kept the stock vent tube and just attached a filter to it. Has anyone else done this? If so, have you noticed any negative effects from it or what did you do to clear this up? By the way, I am sure this has been covered a few hundred times and there is termonology for what I am speaking of, I just haven't learned the language yet. Thanks in advance
Old 11-01-2010, 11:47 AM
shhhhh, can you hear it?
if you are willing to spend a little extra cash on this you could buy a catch can.itll fix all your problems and you could even hook it back up to the cai.but if not i would just keep an eye on how much oil pushes through the filter and change it every once in a while.you should be fine.
Old 11-01-2010, 11:56 AM
where can I find a catch can for mine? I run one on my SS and was curious if you could do the same for diesels? I am new to playing with these, so I have a lot to learn
Old 11-01-2010, 12:04 PM
just do a search for them online.they are all pretty much the same.i know you can buy cheapos off ebay.they dont have to be make and model specific.if you are good in a mill shop you could build your own.
Old 11-01-2010, 12:07 PM
Appreciate it again!
Mine dumps outta a hose by my fuel tank. nice oily mess back there. keeps the leaf springs lubed up haha.
Old 11-01-2010, 12:22 PM
Heres a good one for a cheap do it your self CCV kit.
Welcome to guzzle's CCV mod web page
Old 11-01-2010, 12:29 PM
Be careful with that filter. These engines are sensitive to positive pressure in the crankcase. If you notice a leak, unhook it. NCHornet sells his kit through Raul at Stealth if you don't want to make you own.
Old 11-01-2010, 12:32 PM
I just found this product but the add was on *************. Not sure if it's compatible with the Ford 7.3's so I placed a question into their contact section asking of such. Let ya know when they reply!
Black Oil Catch Can, by Mishimoto
Old 11-01-2010, 12:34 PM
you got this choice as well: CCV Mod
