Help HPOP Replacement.. - Ford Powerstroke Diesel Forum
post #1 of 20 Old 10-27-2010, 09:35 AM Thread Starter
Hey guys, please help me if you can. I'm elbow deep in my 99' 7.3 replacing the HPOP, and have a dumb question. The fuel bowl is off, all of the lines are off, the two 10mm bolts are off and I still cannot take off the old pump. What am I missing? Thanks!!!
Biggatorchomp is offline
post #2 of 20 Old 10-27-2010, 09:39 AM
Derek@VisionDiesel's Avatar
Send a message via AIM to Derek@VisionDiesel Send a message via Yahoo to Derek@VisionDiesel
Did you take the resevoir off? It sits on top of the front of the HPOP and holds the oil. There are like 6 bolts on top of it holding it on.
Once that is off you can see the gear, and a bolt holding that gear on. Once that gear is removed the pump will fall off
1996 f350- 615hp/1258tq uncorrected
2008 KR f350- leveled and tuned 569hp/1158tq
Cascade Coal Rollers!
Derek@VisionDiesel is offline
post #3 of 20 Old 10-27-2010, 09:41 AM Thread Starter
No, I didn't, thanks for the info!
Going to do that right now.
Anything else you want to tell the dumbazz newbie? I'm all ears....
post #4 of 20 Old 10-27-2010, 09:46 AM
Well yes.... That resevoir will make a mess when you remove it. Its hold like a quart or a little less.
You may pump it out first. But i always just let it make its mess then clean it up.
The bolt for holding the gear on is like an 18mm. You will have to take the inspection plate off first. Its 2 bolts, either 10 or 8mm. And to get the bolt off the gear you need someone below the truck holding the engine from turning over, otherwise when you spin the gear the motor will just try and turn over!
When you go to re-install make sure you use some RTV to seal up the cover that protects the bolt. It doesnt have a gasket or anything
post #5 of 20 Old 10-27-2010, 09:55 AM Thread Starter
Thank you Derek...
I'm at the gear now...
I'll post my "Progress" shortly...
post #6 of 20 Old 10-27-2010, 10:08 AM Thread Starter
Ok, gear is off. working on putting the new pump in now, and replacing the gear.
I was able to just take it off with a 18mm wrench, it did not turn the engine over.
I hope that's not a problem.
Thanks!
post #7 of 20 Old 10-27-2010, 10:13 AM
Thanks!
You must just have really good compression hahaha... I never tried it without holding the engine. I just know it will turn it over if you wanted to.
But you should be good to go!
post #8 of 20 Old 10-27-2010, 10:14 AM
Fill the resevoir upon re installation. Leaving it dry and letting the truck fill it up will make the engine run oilless for a second or two!
post #9 of 20 Old 10-27-2010, 10:21 AM
justinlogue5_0's Avatar
I have a question about this as well since I have heard different stories. Once you are done and the new pump has been installed and the new resevoir has been filled up. Do you just crank it and let it idle for a while so it bleeds itself out or do you have to run it 10 mins and then pull some bleed screw etc... I got confused on this while reading the install instructions for the adrenaline pump. Thanks
A little bit of this and a little bit of that. I want a lot more of this and a lot more of that
It never ends!
justinlogue5_0 is offline
post #10 of 20 Old 10-27-2010, 10:29 AM
Not sure on a 6.0
But on a 7.3 letting it idle and driving it bleeds it. I let mine idle like 5 minutes, and then i drive the absolute **** out of it!
Driving it hard is the best way to get air out of the lines
