Go Back   Ford Powerstroke Diesel Forum > Ford Powerstroke 99-03 7.3L Forums > 99-03 7.3L Powerstroke Problems
Old 04-29-2006, 03:45 PM
fyreles fyreles is offline
codes ?
Good evening all,
Just received my new SCT scanner and going to attempt to hop up the stock 7.3, I pulled the code P0470 off the scanner, I think it is an abs sensor on the r frt but do not know for sure, does anyone know where to find this info ? thanks
Old 04-29-2006, 06:06 PM
mschn99 mschn99 is offline
P0470 — Exhaust back pressure sensor circuit malfunction probably causes........Biased sensor, open signal return
there is fords definition of the code....i would first check to see if the EBP pipe is plugged up, but you may need a sensor too. also, check the wiring to be safe.............Marc
Old 04-29-2006, 06:24 PM
more codes ?
I hate to admit I don't knowwhat a ebp pipe is and what wiring ? thanks again, les
Old 04-29-2006, 06:25 PM
coded
Could this be a result of the cam sensor issue with it "bucking" at highway speeds ? les
Old 04-29-2006, 06:34 PM
les, a cam sensor would not throw this code......
The EBP sensor is the exhaust back pressure sensor. there will be a tube coming off of your drivers side exhaust manifold. it will run to a sensor that has a three wired connector on it....thats the guy........Marc
RJacks258 RJacks258 is offline
Ebp sensor is exhaust back pressure, its at the back of the turbo. The valve is at least.
Old 04-29-2006, 06:54 PM
mega code
with out beating this too hard you talked about the tube being plugged, like with blown by oil or something ? les
Old 04-29-2006, 06:55 PM
try blowing through it. there is a lot of carbon in exhaust systems and sometimes the carbon will plug the tube. if it does, soak it in some solvent for a while and then blow it out with compressed air.............Marc
