3 tries to start, white smoke coming out of turbo and then starts
Ok, a question for you guys, hopefully with a simple solution.
I went to start my truck this morning and it didn't catch on the first or second try. It just cranked slower and slower but did not catch. On the second try white smoke starts to come out of the hood. Hmmm. I open the hood and the white smoke is coming out of the joint at the back of the turbo where it goes down to the exhaust. It continues to seep out for a minute or two. I try to start it again same thing. I am now running late for work. Hmmmm. I try to crank it one more time and it fires up right away, but with a puff of white smoke coming out of the tailpipe this time. the weather was about 40 degrees or so and extremely windy during the night, truck sits outside, no garage. Any ideas on where to start? ___________ |
Sounds like your turbo seals have blown out. JUST had this happen on my diesel volkswagen. Should be ok to drive on it for a little while, just keep in mind once the leak gets bad enough your gonna have a runaway diesel on your hands.
just to be sure.. there is a HUGE puff of white smoke right? Not just a little sputter of it? A little white on startup is ok... bellowing white smoke, especially from under the hood coming from the turbo/IC lines, is a sure sign of blown oil seals in the turbo. |
it was just a little seeping out, enough to notice without the hood popped open, but nothing major. After it fired up a burst of it came out of the tailpipe. It has started fine ever since then. I am just trying to head off problems before winter hits
Well if it's just a brief puff, you should be good. If its POURING out, then you have problems.
Scott |
Like I said if it's a brief puff at startup.. its relatively normal for these big diesels. If it blasts the surrounding area with white smoke in what looks like a para-military smoke-screen, then it's more than likely oil being blowing into the intercooler lines (ie bad turbo seals), and the turbo is eating up the oil. Does the truck billow white smoke while driving down the road? Does the white smoke have a funky smell to it? If you are sly enough, take a video and post it unless you think you can answer those questions accurately enough for us to answer. I'm gonna take a picture of my diesel volkswagen w/ bad turbo seals in a few days and post it on youtube to show what its like.
you have glow plug/relay probs if she aint hittin.that whit smoke you see is unburnt fuel,check your glow plugs and the relay.
The white smoke is on start up for 5-10 min depending on how cold it is. It is a pretty good smoke screen. Once it warms up I don't see any more the rest of the day. The truck runs a bit rough until it warms up. Thanks for the help Scott |
Interesting.. hows it boost when its running rough? Does your throttle ever "hang"? If your throttle ever hangs, its feeding off the oil thats running thru the IC. This can lead to a runaway diesel (happened in my Volkswagen.. I was only idling down the road. I put it in 5th popped the clutch and slammed the brakes to stop it)
Yeah, what he said. Mine did the same thing a few weeks ago. Swapped out the burnt out stock style GPR for a Stancor. No problems since.
