CCT Problems - Ford Powerstroke Diesel Forum
Old 10-14-2010, 08:26 AM
CCT Problems
Any help will will help. I have 2002 and did a CCT and found #6 & 8 at fault, so I changed both injectors with rebuilts and I sill have #8 fault. I even switched the 2 injectors around and it made no difference. yes I am using LL injector on # 8. engine still has slight miss?
Old 10-14-2010, 08:00 PM
try a rotational velocity test, as opposed to a CCT. that might tell you more.
#8 can goof the best scanners.
