Turn signal problem... - Ford Powerstroke Diesel Forum
Old 10-10-2010, 06:11 PM
Okay so the left turn signal if you just hit it down like you would normally do the green light doesn't come on and it clicks super fast, yes i know light out right? no the back light is flashing super fast but front one isn't on.. yet if you just hold the switch down like before it locks the turn signal on they both work perfect and if you slowly press it down from there it works sometimes... seems like a problem in the switch but dont wanna have to take it to the shop if its something simple.
Anybody know?
Old 10-10-2010, 06:16 PM
Normally when one light works and the other doesn't then you have a burned out bulb. Not sure in your case but would check bulbs for starters
Old 10-10-2010, 06:18 PM
Please read the whole post, i said were they both work fine
Old 10-10-2010, 06:24 PM
Feedback Score: 5 reviews
Mine does the same thing. I've just learned to push it down a little slower and it works fine
Old 10-10-2010, 06:33 PM
my 05 did the same thing except that when it was blinking fast you could not see the outside lights flashing at all. I replaced the turn signal switch on the steering wheel and all was good again
Old 10-10-2010, 06:41 PM
lol gotcha, just my dad drives my truck some too and i told him about it but i even do it sometimes just push it down and not think about it just dont wanna deal with a cop over it ya kno
hmm did you replace it yourself? and also did you have to replace that whole switch, the turns, wipers, brights ect.??
Old 10-10-2010, 08:26 PM
Powerstroke Techie
Yeah they are really easy to replace(less then half hour). And yes it comes as the whole assembly. Just be careful that you don't break the tabs on the connectors that plug into the switch.
Old 10-11-2010, 09:38 AM
Yea it only took about 15 min to swap. If I remember right it was 3 screws for the cover and 2 to remove the switch and 2 plugs on the switch. The plugs are the hardest part as you don't want to break the tabs. I found my switch on ebay for a great price.
