starting problems - Ford Powerstroke Diesel Forum
Old 06-11-2007, 06:17 PM
starting problems
this is what i am working on is a 02 powerstroke would not cold start and i am talking about 60 deg weather i put glow plugs and a glow pug relay on it now it will start but runs rough for like few min oil is fresh fuel filtler is fresh air filter is good no codes has 160000 on it any ideas thanks
Old 06-12-2007, 12:31 AM
The Fat Mod
Is your HPOP reservoir full? Getting enough fuel?
Old 06-12-2007, 03:17 AM
ADMIN AND TECH
injectors are sticking cold , try to plug it in overnight , if it cranks ok , its time for some injectors, pluging it in wil warm the block and injectors , which will allow them to move easier alowing the popet valve inside to move , when cold its sticking causing hard start rough idle
Old 06-12-2007, 09:07 AM
hey thanks you can plug it in and it will start just fine
Old 06-12-2007, 09:16 AM
ADMIN AND TECH
answered your own question , better look into replacing injectors
